Posted by pete 23 on November 14, 2010 at 10:51:33 from (184.12.34.48):
In Reply to: Farmall 460 carburetor posted by Roger Reeves on November 12, 2010 at 19:06:24:
It cannot run at high speed without air. You indicate the throttle on carb, disconnected , is still in idle position. So,if the butterfly is actually in low idle position you are getting air from someplace else, bypassing the carb, reason you have to choke it so much to create some suction at carb to get any fuel. I would take carb off and check throttle plate and if closing correctly, look for air leaks.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
