Re: Cub Transmission Spline Shaft
Posted by Haas on November 14, 2010 at 13:42:04 from (75.201.205.61):
In Reply to: Cub Transmission Spline Shaft posted by Ran McClenahan on November 13, 2010 at 11:47:49:
Yes, Jim is correct. Likely you installed the front transmission bearing backwards. Which allows the shaft to slide back and forth. A common mistake. You"ll have to split it again to fix it.
