Re: End My Confusion
Posted by Zachary Hoyt on November 14, 2010 at 14:21:06 from (184.12.76.221):
In Reply to: End My Confusion posted by Joe Bly on November 14, 2010 at 14:00:33:
If it is a mag in my experience the distributor cap will be mounted horizontally, pointing toward the rear of the tractor. That is an IH H4 mag. Distributors that use battery voltage usually are vertical, pointing up, in my experience. I don't know how to tell the make on them.
Zach
