More thal likely it is a pinhole in the intake pipe from the reservoir to the pump (larger diameter suction pipe or hose) If it is leaking air, it might not leak fluid. Orings where they attach to either end can be bad, and the hose can have broken layers that suck air and flap shut to prevent leaks from showing up. Careful use of a squirt oil can filled with hytran, and good light, with it running can find spots sucking in air. If there are wet spots on the suction hose, clean them and use some black vinyl tape to temporarily stop the suction leak. If it works, replace the hose/line. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
