You read my mind! Make sure the wire going to the light switch is good. Here is a test. use a marker or instrument light, (bulb) and pull the Bat wire off of the alt. place the bulb between the wire terminal and the stud, such that electricity can flow through the bulb. It should not light. If it does, the alt has a bad diode in one of the diode trios. If it does not, make sure the bulb does light if it is held to a ground, and the terminal that is disconnected. If it does, reattach it. If it does not, there might be a problem with that wire, or its connections, or the amp meter connection. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
