OK. Is there a difference between a volt meter and an ammeter?? If it helps you any, this one reads from 0 - 20 or 30. Its home position is at the 0 to the far left unlike some of the others I've seen which are in the middle.
I can start the tractor, and the meter reads NOTHING. I can pull the switch, and it will read approximately 11. Rev the engine and it doesn't change a bit. Push the switch back in and it reads Nothing once again.
The diagram I drew is labeled as it is on the actual meter, LOOKING FROM THE REAR.
