Re: Farmall 460 carb problem
Posted by CNKS on November 14, 2010 at 17:45:46 from (216.144.104.128):
In Reply to: Farmall 460 carb problem posted by GWMILLER on November 14, 2010 at 15:23:33:
The other screws are idle mixture and idle speed. Idle speed is self explanatory, make it fast enough so that it runs smoothly and doesn't die. Maybe 4-600 rpm. Same way with the mixture, in or out until smooth. Lean is out rich is in. Turn the load screw 5 turns out, that is max power, it will run and get better fuel consumption turned in 1-1.5 turns, or whatever works. You do not adjust it as in the earlier models prior to the Super H/M. Which is in until rough, out until smooth. If you do that it will be too lean. If that does not work, you need to disassemble and clean it again, possibly it needs a kit.
