Re: End My Confusion
Posted by CNKS on November 14, 2010 at 17:57:24 from (216.144.104.128):
In Reply to: End My Confusion posted by Joe Bly on November 14, 2010 at 14:00:33:
There are only two carb options, distillate/kerosene, and gasoline. Does the serial tag have an X1 suffix? If so there is only one carb for it, the gasoline one. The other is the distillate/kerosene carb, most of the parts are the same. If you don't have a parts manual, look at the parts section in www.caseih.com. The year does not matter. For the M the choke lever is on the outside, for later models it is on the inside, next to the block. It is possible, but not too likely that the carb has been changed -- in that case you need to look for the numbers.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
