Re: tractor problems
Posted by pete 23 on November 15, 2010 at 10:21:09 from (184.12.34.48):
In Reply to: tractor problems posted by Bruce Bell on November 15, 2010 at 04:37:34:
I think the guy who told you clutch was on the right track. The backing plate on the clutch drives the pto and all hydraulic pumps. The splines strip out on shaft and backing plate. Can take a look under clutch and if you have fine shavings you know where the problem is . It is kind of hard to see the actual splines where they strip off but it can be done.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
