Re: Serial numbers on M
Posted by glennster on November 15, 2010 at 12:14:39 from (76.224.2.138):
In Reply to: Serial numbers on M posted by David Morehouse on November 15, 2010 at 11:35:15:
re the two speed pto. if the tractor has an aftermarket 9 speed attachment, running the 9 speed in high range will give the faster pto speed.
