Re: M Rear Wheel Bearing lube?
Posted by Janicholson on November 15, 2010 at 15:56:10 from (67.72.98.45):
In Reply to: M Rear Wheel Bearing lube? posted by IndiRon on November 15, 2010 at 13:11:13:
There is a grease zerk at the end of the housing that needs ~19 pumps before running (preferably with the wheel rotated 1/4 turn between groups of 3 pumps or so). After that once a week if worked, or as the manual indicates. If a show tractor, once a year! It will not squirt out of the end cap. Jim
