Re: M Rear Wheel Bearing lube?
Posted by Janicholson on November 15, 2010 at 16:05:18 from (67.72.98.45):
In Reply to: M Rear Wheel Bearing lube? posted by rustred on November 15, 2010 at 13:11:13:
After the initial lube the number of gun pumps shoulD be changed to 4 for each normal lubing. Jim
