Re: Add a block heater to an H
Posted by roy prins on November 15, 2010 at 16:49:50 from (96.31.4.122):
In Reply to: Add a block heater to an H posted by Larrydw on November 15, 2010 at 10:35:37:
you should drill a hole below the thermostat and tap it out to 3/8ths pipe thread and put in the proper nipple-- the heat from the heater will go back into the head where it belongs-- suck your cold water out of the plug behind the carb.good luck!
