Re: Super A stuck front end
Posted by outlar on November 15, 2010 at 18:04:40 from (74.198.8.57):
In Reply to: Super A stuck front end posted by Mark W. on November 15, 2010 at 09:38:17:
[quote="Mark W."](reply to post at 10:38:17 11/15/10) [/quote
Lay off the heat or last resort. Disconnect the steering gear, Take out the steering knuckle post, then install a pipe through one side of the axle.
This pipe will have an expander on the end to drive the opposite side out. Barring that, remove axle and soak vertically with your choice penetrant.
Barring that, cook the front axle in a electrolytic bath after having been removed from your super A.
Try not to stress the pipes to much Good Luck, I have a electrolytic bath procedure if the first 2 methods fail.
