Re: Serial numbers on M
Posted by gene bender on November 16, 2010 at 01:59:41 from (67.55.227.196):
In Reply to: Serial numbers on M posted by David Morehouse on November 15, 2010 at 11:35:15:
You have an overdrive on your tranny that will give you also two speeds on the pto. Outside of that there is no two speed pto.
