Possible, yes,likely no. Jack it up, loosen wedge bolt until it starts to force against wedges trying to push them apart. Then turn wheel so key side of axle is down. Strike top of axle at the end with like a four pound hammer. Use lots of penetrating oil. Keep trying to turn bolt and wack it again. If you are lucky the outer wedge will come out, and then you can take a large heavy bar and with a large or larger hammer drive inner wedge out of wheel. If the inner wedge is the one that comes loose first it is really difficult to get enough pop to drive that outside one out. Oh, after one wedge comes loose turn wheel again so wedge is on bottom. That wack on the axle is what will get it's attention though. Before we had the good horse shoe removal tool the wedges were a real problem. All the earliest tractors came with was a pair of large headed pins to hook each end of wedge.Didn't work well. Also, when tightening them, lots of anti sieze and again use the tap on axle to seat wedge, no point in over torquing them as that will only damage threads.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
