Re: Cub won't stay in first gear
Posted by Janicholson on November 16, 2010 at 14:55:37 from (67.72.98.45):
In Reply to: Cub won't stay in first gear posted by paulntxk on November 16, 2010 at 10:54:51:
Four things that are in the mix of potential causes:
Worn gear teeth from some one grinding it into gear.
Replace the gears on both the countershaft, and main shaft.
Worn bearing between input shaft and output shaft on the main (top shaft) or worn front or rear main trans bearing.
Broken or week detent ball and spring in shift rails. (easiest to get at and fix)
Bent shifter fork, not allowing full gear mesh. Also modestly easy with the removal of the cover. Jim
