Re: Farmall A coolant capacity
Posted by James Rumph on November 16, 2010 at 15:02:01 from (96.27.101.101):
In Reply to: Farmall A coolant capacity posted by bkpigs on November 16, 2010 at 06:19:54:
Has it had a water pump installed ? If not and it is still stock it will just spit out what it doesn't need.
When you fill up a thermal syphen system it will spit the excess out the over flow. It should have a zero presure cap as well.
