Re: just got tractor ...first of a whole bunch o' questions
Posted by GordoSD on November 16, 2010 at 16:34:43 from (216.106.252.55):
In Reply to: just got tractor ...first of a whole bunch o' questions posted by realolman on November 14, 2010 at 06:14:31:
What does the oil that is in there look like?
Drain a little off from the filter housing.
I'll bet it is really black. If so, add a quart of diesel fuel, start it and run it at idle for 15 minutes.
Then drain the crud, drop the pan, and pull the filter housing.
Clean it up and add 5-20 if you are going to start it outdoors colder than zero degrees F.
AT those temps you definitely need a block heater also.
Gordo
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
