Re: How to remove stuck wheel wedge bolts
Posted by Ed3 on November 16, 2010 at 18:59:56 from (24.47.208.126):
In Reply to: Re: How to remove stuck wheel wedge bolts posted by skycarp on November 15, 2010 at 07:26:35:
I think the tire blowing up is when you apply hear
to the rim and the air expands so fast that the
tire explodes.
Heating the wedge on the axle won't heat up the
rim.
If it's rusted that bad You will need to heat up
the wedge to get the bolt out and in the end may
need a new wedge.
Once I got by with some grade 8 bolts and nuts.
Had to grind down the nut to work.
