Re: Farmall A coolant capacity
Posted by John M on November 17, 2010 at 03:07:11 from (67.231.170.204):
In Reply to: Re: Farmall A coolant capacity posted by bkpigs on November 16, 2010 at 17:55:17:
Without a pump, it doesnt mix as fast as it would with a pump. You may have a spot where the freeze level "could" be lower than the rest of it, and that part "could" freeze and cause damage. I personally only have 2 tractors with thermosyphon systems. I did premix one, its a Cub, and doesnt hold much to start with, but I didnt premix my 14, just dumped a gallon of AF, then a gallon of water, and so on, and I havent had problems with either, but I live in the south so it doesnt get cold enough most of the time to do any damage. My buddy up north, he has/had a F30 that has a busted lower casting because he didnt premix, but I think he just didnt have enough AF in there to start with.
