You can't just dump oil on a rusty bolt and expect instant results.
For the oil to do any good it has to get in BETWEEN the bolt and the threads, or the bolt and the hole. When you're talking about rusty bolts, there's almost ZERO room for the oil to get in.
If you've got the time, you really need to spritz a little bit of actual penetrating oil on the bolt every day for several days. Soaking the area heavily is a waste of oil, as most of it just runs off.
If you ain't got time, penetrating oil is a waste of money. Heat is the only way you're going to get instant results on a stuck bolt.
When someone tells you Brand X penetrating oil is great because they sprayed it on a bolt and it came right out, that bolt wasn't stuck.
When someone tells you Brand Y penetrating oil is no good because they sprayed it on a bolt and it did NOT come right out, they don't understand how penetrating oil works.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
