Re: 350U adding remotes
Posted by JSB on November 17, 2010 at 10:34:30 from (199.188.45.1):
In Reply to: Re: 350U adding remotes posted by Janicholson on November 17, 2010 at 08:36:23:
Alright, the tractor has 2 hydro levers on the right, I see the access plate (at the rear lever) it has 2 ports with plugs on top, and the access below has 2 lines for the 3 point and 2 ports with plugs. So can I use the existing setup/ports or do I need other parts.
Thanks
