Yes soak the carb. But do yourself a favor and clean it before you do. If it is your typical been on the tractor a while carb it will be pretty grubby on the outside and you don't want chaff and grit in your can of cleaner along with your carb. Get and old toothbrush and a spray can of carb cleaner and thoroughly remove any crud you can and then soak it. Be sure to clean your sediment bowl and have a good critical look at your gas tank before you put your newly cleaned and kitted carb back on and start trying to run it. I have taken to using a temporary rubber gas line with a gravity compatible filter for the first few weeks (or months) to make sure any issues I might have are not related to adding dirt into the equation. MAYBE you can avoid some of the mistakes that I made. HTH
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
