Re: M wiring
Posted by Docs69 on November 17, 2010 at 13:58:30 from (74.234.175.141):
In Reply to: M wiring posted by Docs69 on November 17, 2010 at 11:03:37:
Correction!!!! It's negative ground but all the pictures of the amp box and light switch connections are positive ground and 6 volt. Sorry for the confusion. I need the connections for the fuse and light switch on 12 volt-neg. grd.
Doc
