Re: Attaching rubber belting to steel wheels
Posted by Craig Thoricht on November 17, 2010 at 14:34:38 from (75.185.183.244):
In Reply to: Attaching rubber belting to steel wheels posted by Tom in Iowa City on November 17, 2010 at 13:00:44:
This may not be the best way,but it worked for me-I jacked the wheel up and clamped the rubber in place,then used a regular high speed bit from underneath up through the rubber. I used carriage bolts and bolted the first ones in tight,then worked my way around the wheel doing my best to keep the rubber pulled as tight as possible.
I didn"t cut the ends square but cut them roughly on a 45 degree bias and didn"t worry too much if there was a gap. With the bias you won"t feel a bump at every wheel revolution.
That"s how the Amish do it around here and it worked well for me.
Good luck. That"s a fine looking tractor there.
