Re: OT: Maul/Sledge New Handle Install
Posted by Lmack on November 17, 2010 at 15:00:41 from (72.145.202.12):
In Reply to: OT: Maul/Sledge New Handle Install posted by Dellbertt on November 17, 2010 at 13:54:10:
I have installed a large number, and if you have the correct size, it should slide on . . . with a little encouragement. If you can get it started so that it will stay on, jam the base of the handle into a solid rock, stump, or slab until the tip of the handle is flush with the head of the hammer. Do not continue until it stops and cut the excess off, it will shorten the life of the handle. Then use the wedges furnished to tighten it up using a wood wedge first in the precut slit followed by a steel wedge across the wood wedge.
