Posted by farmallhal on November 17, 2010 at 15:16:53 from (76.2.184.96):
In Reply to: Re: Farmall H or C? posted by outdoors on November 17, 2010 at 12:58:11:
A couple of things you might not be aware of on the fast hitch SC and 200's. There is an adapter hitch that fits in the fast hitch prongs which allows the use of 3 point implements. It was made by IH and I have one but have never used it so can't give any pro and con's on them. One item that is a little expensive on the SC then other same era Farmalls is a grill. So if you find a SC with a smashed up grill finding a replacement is going to be somewhat costly. The SC uses a grill that is taller by an inch and half so regular C grills won't work. The same grill might be used on a Super A but I'm not sure since I don't have one but they are somewhat scarce. Another thing the 36" size rear tires are more expensive then the larger 38" tires used on the H's and M's. I believe it is because that size has very limited applications and aren't made in the larger quantities the more common 38" are and by far fewer manufacturers. I did see that the electric start was an option on the regular C tractor but isn't as clearly stated in Guy Fay's Farmall Tractor Data book for the SC. I do recall a lot of Farmalls in the later 1940's were still hand cranked and I think by the 1950's the trend was toward electrical starting and the 200 probably was such. I would be surprised if it didn't have hand crank features anyway though. I sent you an email as well you should have received, HTH, Hal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
