Re: 674 FUEL PUMP ISSUE
Posted by Jimb2 on November 17, 2010 at 18:02:57 from (99.240.236.11):
In Reply to: 674 FUEL PUMP ISSUE posted by jiminny on November 17, 2010 at 16:02:55:
Hi Jimmy, try pressurizing the fuel tank with an air gun and a clean cloth stuck in the tank filler.
I assume you have the STOP/START/RUN control cable adjusted properly. Was the static timing adjusted? Although this will not cause the pump from pushing fuel to the injectors, only causes starting and running problems.
JimB
