Re: Zenith carburetor rebuild
Posted by rustyfarmall on November 17, 2010 at 18:11:00 from (209.152.78.140):
In Reply to: Zenith carburetor rebuild posted by gene bender on November 17, 2010 at 09:45:34:
That venturi was most likely pitted before you put it in the cleaner, but you couldn't see it because of the other dirt. Most of the venturis that I remove from the H and M carbs are already pitted. I just clean them up the best I can and put them back in. The tractor never knows the difference.
