Re: M wiring
Posted by Janicholson on November 17, 2010 at 19:19:20 from (67.72.98.58):
In Reply to: M wiring posted by Docs69 on November 17, 2010 at 11:03:37:
The fuse should be on the supply side of the light switch as this protects the most components.
Amp gauge, fuse holder side terminal, fuse holder rear terminal, light switch. I also recommend a fuse link in the Alt output (heavy) wire this can prevent tractor fires if a diode pack goes in the alt. 5 amps greater than the Alt amp rating. Available at NAPA or other store. Jim
