Re: Attaching rubber belting to steel wheels
Posted by Janicholson on November 17, 2010 at 20:10:04 from (67.72.98.58):
In Reply to: Attaching rubber belting to steel wheels posted by Tom in Iowa City on November 17, 2010 at 13:00:44:
The drills shown will be OK, but they can heat up pretty easily and when hot they melt into the rubber and suffer to make a clean hole. I drill non metallic materials often, be have had luck with small hole saws from machine tool vendors, and rotozip bits. Forstner and brad point bits are usually not very hard material and can be sharpened with a file. Thus they will dull easily and if heated nuch will loose all temper. Good luck Jim
