Posted by John A. on November 17, 2010 at 21:02:55 from (76.1.122.180):
In Reply to: What's a 350 LP worth posted by Blackland Dan on November 17, 2010 at 19:30:57:
Blackland Dan, That tractor should be well worth what you are saying if all points are equal.....But till you get it home and check it out there is slim to little chance you will break even doing what you say. The cost of a paint job will run close to $1000 to $1500 after paint. That is not figuring all your time either. $2250 may be too high, If you could get it in the $1500 range then you have got wiggle room but, at $2250 then + the cost of a well done paint job the margin is tight to make real money, over just the cost of breaking even. If you plan to keep it for a few yrs then that is another matter, then Go For It. Hope this helps! Later, John A.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
