Re: Hydraulic distrubutor type pump
Posted by Allan In NE on November 18, 2010 at 02:13:04 from (148.66.88.254):
In Reply to: Hydraulic distrubutor type pump posted by Chris in Ar on November 17, 2010 at 20:07:12:
First,
Go back in the belly and remove that drive shaft coupler to the belly pump. Then, remove the belly pump lever.
Tie the belly tank to your "extra" tank for more capacity.
Put a "T" in the belly tank drain plug.
Mount a separate control bank up at the headlight bar.
Input hose of the live pump goes to one side of the "T" and the return of the control bank to the other side.
Output of the live pump goes to the inlet side of the valve bank.
Lastly, forget the three original outlets from the belly pump and just hook your "work" hoses to the control valve.
Allan
third party image
third party image
third party image
