Re: Zenith carburetor rebuild
Posted by bjb in Tx from Ne on November 18, 2010 at 05:24:36 from (141.197.12.183):
In Reply to: Re: Zenith carburetor rebuild posted by bjb in Tx from Ne on November 18, 2010 at 05:23:08:
One last thing, I use string trimmer line and fishing line to run down all the passages I can find and make sure the small ones are not plugged.
