Re: Attaching rubber belting to steel wheels
Posted by Loren in Iowa on November 18, 2010 at 06:23:25 from (207.177.2.187):
In Reply to: Attaching rubber belting to steel wheels posted by Tom in Iowa City on November 17, 2010 at 13:00:44:
Tom-We used a regular wood bit to counterbore the rubber, then drilled down through the center of the counterbore, with regular steel bits. Used carriage bolts. Cutting the rubber at a 45 degree angle sounds like a good idea. It is a good idea to keep the rubber pulled fairly tight, as you go around the wheel. Buy an extra pack of cigsrettes, as the process takes some time, but will look nice, when you are done.
