Re: Best way to time a farmall H?
Posted by James Rumph on November 18, 2010 at 17:48:36 from (96.27.101.101):
In Reply to: Re: Best way to time a farmall H? posted by Hunter Burnett on November 18, 2010 at 17:06:45:
Did you take the dist apart ?
If you did , did you put the exact same screws back in that hold the points plate ?
If you used differnt screws they hit the advance weights causing all kinds of problems.
The side of the dist has that stud that a wire is hooked to ! That stud "can not" touch the metal of the dist, it will act like a ground.
I guess i should first ask do you have the dist installed correct ?
Keep giving us answers and one of us will find the problem.
