Re: Best way to time a farmall H?
Posted by wayne in mn on November 18, 2010 at 18:06:24 from (24.179.171.35):
In Reply to: Re: Best way to time a farmall H? posted by Hunter Burnett on November 18, 2010 at 16:50:07:
The timing marks are on the front pulley, not on the flywheel. No need to see the flywheel unless you are looking for worn starter ring gear teeth.
