You can use a simple ohm meter to see if a coil is BAD buttttttttttt it will not tell you if its GOOD. Theres typically say 1.25 to 3.5 ohms (depedns if a 6 or 12 volt coil) in a coils LV primary between its lil + and - terminals and maybe 5,000 to under 10,000 ohms in its HV Secondary. If either is open (no continuity) the coil is baddddddddddddd but even if it passes both those checks, it can still fail once its warmed up especially a HV breakdown failure which youre not gonna see with that LV ohm meter test.
Likewise an ohm meter will show if a condensor is baddddddd but it cant tell you how good it is or its MFD rating or if its leaky, it takes a real capacitor tester to do that. Using a DC ohm meter it should show an open circuit once its charged but if its a short its baddddddddd. If you have an old analog ohm meter like my Simpson 260 a kickback/charge test can tell a bit more about how well and if shes charging up or not.
Good way to test a coil is wire it up and allow curent to flow then interrupt the current (simulates points closed then opened) flow n see if theres a spark by using a coil wire out the top tower to ground.
My Ignition troubleshooting shows other coil checks
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
