Re: The great Super C vs Straight H debate...
Posted by HUH on November 19, 2010 at 04:54:19 from (4.225.89.206):
In Reply to: The great Super C vs Straight H debate... posted by Pete76NY on November 17, 2010 at 21:53:19:
Pete, do you have a picture of the right side of the tractor? So we can see the bellhousing.
Neighbor has a SC with a STOCK COMBINE ENGINE that makes 50 hp!
I pulled it before and after the engine swap, the stock engine was done at 3800lbs, pulling off the exact same hitch you have there,
put in the other engine it would run 5000lbs and not break a sweat.
Broke the rear hubs clean off the axle though,,
