The 460 is the replacement for the Farmall *H* (really the 350), not the M.
A healthy M should be able to run circles around it. It's a heavier tractor with at least as much HP, and gobs more torque due to the larger pistons and longer stroke.
Heck, a healthy 350 can run circles around a 460.
Really, the 6-cylinder engine on the 460 is too small. It runs smooth but it has limited torque because of the short stroke and small pistons.
As long as you can keep the engine running above PTO speed, you have good power, but if you try to lug it down like an M, you will be sorely disappointed.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the
... [Read Article]
Latest Ad:
[More Ads]
