Re: Farmall 460 - Discuss Easy Way To Get Extra HP ?
Posted by IH fan on November 19, 2010 at 08:09:36 from (208.189.32.151):
In Reply to: Farmall 460 - Discuss Easy Way To Get Extra HP ? posted by randy hall on November 18, 2010 at 08:14:02:
I think it would take more than reving up the rpms to gain much HP. Then you may not have enough carb to handle the added rpm and the cam/cam timing and ignition timing may not match up as well. All those things were most likely designed with the rated rpm in mind.
