Re: 12 volt conversion
Posted by Janicholson on November 19, 2010 at 08:23:03 from (199.17.6.126):
In Reply to: Re: 12 volt conversion posted by John T on November 19, 2010 at 07:53:21:
I think it was a very contentiopus discussion. I believe it is important to have it between the ign sw and coil. My logic is founded on two ideas. The first is that the coil and condenser act as a spring for electrons between them as the coil collapses on trigger. (I do not want a resistor between these two active elements, even if they are in a series circuit with all other components through the battery and ground.
The second is that some resistors are coils of nichrome wire that could make a magnetic (incremental) change in the flow of charge during collapse and current dampening in prep of switch closing on the trigger. Jim
