Re: 12 volt conversion
Posted by John T on November 19, 2010 at 10:18:20 from (66.244.97.31):
In Reply to: Re: 12 volt conversion posted by rustyfarmall on November 19, 2010 at 08:18:32:
Rusty, its still a series circuit (regardless where ballast is located) and the voltage dropping (12 to 6) current reducing (8 amps to 4 amps) ballast drops approx 6 volts leaving 6 across the coil sooooooooooooo regardless where its located NOOOOOOO the coil wont overheat. That part (overheating or too much coil voltage) is NOT the concern.
Buttttttttttttt when the points just break open theres some interaction ringing going on between the condensor and coils primary and if the ballast is there in between it changes the dynamics to some degree such that there may be less energy for discharge across the plugs gap.
This help or make it worse lol
John T
