Re: coolant question
Posted by CNKS on November 19, 2010 at 13:38:21 from (216.144.104.128):
In Reply to: coolant question posted by bkpigs on November 19, 2010 at 11:00:13:
Not likely that the concentrate is defective, unless it came from China or somewhere -- you might try a different gauge. Also if you did not drain the block, you have a lot of the old antifreeze still in it. Depends on what the old antifreeze tested. If you flushed it, you have to get all the old water out to get an accurate reading.
