Re: No throttle response on A
Posted by Brian Schmidt on November 19, 2010 at 16:46:47 from (69.66.236.124):
In Reply to: Re: No throttle response on A posted by Red Dave on November 19, 2010 at 15:50:58:
It is not as easy as an H or M with a cover. You have to remove the hood and grill sheet metal. Then if you can get the fan shroud out that really helps. Then the gov casting comes off. Try to leave the gov engaged so you don"t have to worry about timing. Then the spring is right there. It isn"t that bad, but still 100 times worse than an H or M with a cover on the side.
