Put 10 OHM 1 Watt resistor across the leads of a new bulb. Get a bulb for automotive dash, or marker light use (not a diode light, bulb only). This will provide the needed resistance to start the charging. It also provides the needed current limiting to prevent the tractor from continuing to run (back feed from alternator to ignition). The radio shack bulb may be designed for real 12 volt applications like in a computer. Automotive bulbs are rated for 16volts and live well on 14.6 to 15 all day long. Best of luck, Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
