Re: IHC 584 unknown dashboard warning light
Posted by Jimb2 on November 20, 2010 at 17:56:24 from (174.35.246.28):
In Reply to: IHC 584 unknown dashboard warning light posted by DrLee29 on November 20, 2010 at 16:50:07:
Hi DrLee, the light with the lighting bolt is the alternator or generator not charging light.
The other light is a drop of oil and I believe is the transmission lube pump pressure. The engine oil pressure is the light with a crank shaft with a piston on top. On my brother's 684, both the engine oil pressure sensor and the transmission lube pump pressure sensors have failed. The engine oil pressure sensor is the mushroom looking device with a single wire on it and screwed into the top of the oil filter mounting assembly.
The transmission lube pump pressure sensor is under the seat, again a mushroom looking device with a single wire on top. Remove the wire from the sensor and the light should go out.
Hope this helps
JimB
