Re: M carb float issues
Posted by Dan in Ore on November 22, 2010 at 03:47:39 from (66.190.233.82):
In Reply to: M carb float issues posted by Dick Binfield on November 21, 2010 at 18:03:46:
Are you certain that the float is fixed? Even a small amount of gas in the float can make it sink.
I learned long ago to not try and repair a float if at all possible. It also may be that the weight of the solder that you put on the float is causing it to sink.
If it ran good when you first put it together, and later started flooding, I would replace the float.
Just my $0.02.
