Re: farmall tach drive distributor?
Posted by tempola on November 22, 2010 at 04:48:59 from (174.125.79.143):
In Reply to: Re: farmall tach drive distributor? posted by WSJ on November 21, 2010 at 22:05:50:
third party image
Nice tach, where did you get that?
actually either mechanical or electronic would work. its a little pulling tractor I built. amd yes, its a 135 CI power unit with pertronix ignition,.
Andy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
